My independent said that a c220 is 50k at £200 I've just had my E220 changed at 66890 miles but it didn't need doing until 72k but got it done cost for E220d £400 as filter is built into the oil pan2011, 100k miles. Is it time to do a Transmission fluid change?
The filter isn't built into the pan, but the pan needs to be removed to change the filter. The sump magnets also have to be cleaned or changed, genuine parts alone are around £150 if anyone fancies DIY.My independent said that a c220 is 50k at £200 I've just had my E220 changed at 66890 miles but it didn't need doing until 72k but got it done cost for E220d £400 as filter is built into the oil pan
The filter is built into the pan on the 9G gearbox which is fitted to the W213.The filter isn't built into the pan, but the pan needs to be removed to change the filter. The sump magnets also have to be cleaned or changed, genuine parts alone are around £150 if anyone fancies DIY.
yes thats what they told me that the filters are built in on the 9G box lot on here saying needs changing at 77k i was told 72k but done now so i wont be getting it done again on this car total for A service and gearbox oil change £672The filter is built into the pan on the 9G gearbox which is fitted to the W213.
Oh my, my old C220 from 2011 I don't think ever had it changed and I was at 220,000 miles5 years 77,500 miles
I “think” it’s a one off (once only ) change of atf on the 7g+ with MB ?You might be able to get it done under a Service Care Plan. If your car is the facelift with the 7g+ box, then it is due it's second ATF change this year and should be covered. Other than that, a good independent specialist.
My 2012 c204 is "once at"
I keep seeing that - drain the TC, but how?......Make sure that whoever does the ATF change includes draining the TC as well.
