Again, as per message to ToeKnee - can you enlighten how you actually do it then - for the correct gearbox - the 722.6 5g (not 7g). Is there a drain plug? Or some procedure to do to get (as much as possble) fluid out of the TC?
How do you 'Do it right' (and of course it needs doing more than once in its lifetime btw!) And, with the greatest respect, I would beg to differ that not doing it at all is far worse than at least changing as much of it that you can (and then doing it again (much) sooner than needed).
Looking forward to hearing back. Thanks in advance.
