The seat cushion is a complete unit, and Artico Anthracite is a common choice. Are you sure you can't find a second hand seat cushion on eBay? Try obtaining the MB part number and searching that, with a bit of luck the cushion will be the same also for other models (I.e. not just for the A205).
Also, the seat cushion will incorporate the front passenger occupancy sensor mat, and the heating element (if fitted), so ideally you'll want your cushion to come with these, or you'll need to move them from the old cushion.
