C220D P13F600
Alexmc106
Kent
C205 C220D Coupe
Hello,
I am new so sorry about the first message... but I've been working through issues with the adblue system inherited with the purchase of my car. There was some damage to the adblue injector wiring which I repaired and cleaned out the injector while I was there. According to my cheap diagnostic both NOX sensors are generating readings and a DPF regen did kick in the other day. The tank level readings seem accurate as I drained the system then refilled with fresh. I believe the system is now functional but when I scan the car I just get the P13F600 - Exhaust aftertreatment system tampered with and P152100 - Starter disabled by the exhaust and no further codes. (The previous owner had wired a separate starter so that the vehicle can be used but pretty sketchy). Am I right that its a 'dealer level' diagnostic required to clear this code and if so is anybody able to help me reset it? Is remote reset available too? I'm in Kent/South East. Is getting this reset then using the car the only was to see if any further faults return? Thanks.
This guy, a forum member may be able to assist.
Worth a phone call to him anyway.
