C261E code on 2005 CLS320
Paulfbsb
Swansea
CLS320
Hi all,
I’m showing a c261e code on my cls after the brakes going to reduced brakes press pedal full on and start engine red warning message.
If I restart the car it disappears and drives normally into I push the brake pedal a couple of times and it will for no further than a couple of inches and then the brake pedal will stop like dead like and is solid if I release it it goes back to normal and then sometimes throws the red brake warning I describe above.. just trying to nail down what it is to get it sorted. I’ve changed the break switch for a Mercedes genuine one in case it was that but still the same...
mall help is appreciated if you can point me in the right direction of what it could be before splashing out big time...
cheers
Paul
