DamoC43
Hi all, So there are quite a few posts about DRL issues but none of them seem to draw a conclusion. I will make sure that this one does - assuming i solve it of course!
Car is C43 S205 2019 plate
Head lighs are multibeam part no: A2059069505
So fault is i was driving when error messages popped up on dash - Side light, turn signal, parking light malfunction. When i stopped to check the DRL on passenger side was flickering and the indicator was not working. Inside the car the indicator switching was super fast - indicator on side mirror and rear cluster passenger side woking fine. Drivers side everything working as normal. Headlight had a bit of condensation so i left some silica packs in over night. This morning on first start DRL was running fine but as soon as i put on left hand indicator the fast switching ensued and so did the flickering DRL or it stopped all together. I discovered the module for DRL's is the smallest one of the 3 on each headlight assembly and i happened to have a spare from the original headlight i replaced some time back so i switched them over this morning but no joy. The rest of the passenger headlight functions fine though (Low / High beam).
I've checked for a signal at the plug - apparently i should be able to detect a 0 to 12v alternating signal on one of the plug wires using multi meter but I can't detect one. Have confirmed 12v supply is there. I also tried plugging the old headlight back in after i'd switched the modules over but still nothing however that headlight had the 2 main modules missing so doubt that was a fair test.
So my question really is:
A) Should i be able to detected an alternating voltage at the main headlight plug with indicators switched on - using a multi meter? I've already confirmed i have a good ground and 12v supply. I can verify this myself tomorrow by testing on the drivers side.
B) Can i also trace the same wire back to SAM module (assuming above point is valid) and check there too. Current assumption is that it's a SAM related fault. I'm also struggling to work out if the SAM module is up near the battery or is in the cabin on passenger side?
I've also scanned and picked up a bunch of faults mostly comms related errors B162A64, B16EF64, U118A08, U118A67.
Any advice much appreciated. PS: I like to try and solve such issues myself so please don't suggest i take it to a garage - i will if i can't solve but i'm not giving in just yet.
Any additional info required please let me know
