Hey Guys.. Some of you may Know that I now produce OEM Grade 507 Edition Decals,
OEM pattern and Vinyl Grade 507 decals.
These are an exact replica of OEM decals. The pattern was taken from an original set for the template, Cut in OEM Grade Mactac Pro 900. They are the exact same colour as OEM but in a satin finish.
These can also be produced in any colour from the Avery or Mactac Pro series Vinyl.
£75 per set Inc Delivery, will fit Coupe and Saloon Models
Professional install advised.
Pls Make sure that these are fitted correctly guys.. the OEM design is not supposed to be wrapped around panel edges as it will change the profile of the decals, and can cause peel back.
Pls see attached pics exact OEM Fitted decals.
please PM me for any info or orders.
Now also available in Carbon Fibre 2x2 weave textured Wrapping Vinyl £200.00 Inc Post
Carbon Fibre 2x2 Texturerd Weave Pro series Vinly
OEM Grade Mactac Pro 9800 series Fitted to my car
