I have just got my hands on xentry diagnostic tool but i dont know how to see trims in it lol
This cheap tool is just reading what the ecu is seeing never taught it would matter if its a cheap tool or expensive one
Yes both banks show same amount of negative LTFT -13 to -14 on idle but on driving it does down too -7 and goes up and down depending on paddle input
Its not throwing a cel as the thrust is -25 or + 25 ideally it should be +or - 5% could be weak plugs not burning fuel as much as they should but again it shouldn’t effect both banks not all plugs would be weak , maybe the oil is contaminated with fuel as car used to run super rich and gave cel -25 but after changing the MAFs and filters it dropped to -10 to -14ish
I suspected that the injectors might be leaking ao i put in new injectors
turned out my old injectors were perfectly fine as well .
I changed the lifters thinking they might be weak but made no difference plus mine older ones were good as well.
Installed a new intake manifold off a parts low mileage car suspecting that manifold might be bad but that made zero difference and i wasted 1100$ on it
Only thing left too change is
Exhaust manifold gasket
Plugs
Oil
Other than that im out of ideas
I could get a tune by which the tuner can adjust the trims to near +- 5 but i want to keep 100% stock
