C63 LSD - Diff housing shaving
Ashventini
Daventry
C63 AMG 507 Edition
Hi all, I'm new here. Just joined. I've just bought a low miles 2014 507 Edition. It doesn't have the 471 LSD, so its a must for me to bolt on either a Quaife or a Wavetrac. Im leaning toward the Wavetrac because of the slightly improved characteristics. Its 2 horse race between these 2 as i don't want to go down the clutch plate route as they are not maintenance free. I know this as my father owned Gripper Diffs, so id have one of those otherwise. My question on the Wavetrac is about fitment. I read some owners need to have the diff housing shaved or fettled to fit the new diff inside. Is this correct? Is it minor I'm guessing? I suspect if so its a question of just grinding away a little cast material somewhere? Can anyone advise on this - also if its an issue on earlier cars or all. My car is 64 plate. Thanks.
Also when replacing the diff, what other parts should I change out (that doesnt come with the diff). Oil seals? Can anyone send a link where to get them at decent price? What sealant should be used on the housing when re-building? What fluid/oil to use?
Thanks. Will be asking more question son other matters also.
Hi there
I fitted a wavetrac lsd to my 507 saloon, a must!! yea every so little to shave off the housing to fit, I replaced the all the drive seals, got from my local mb dealer, the oil was what wavetrac recommended , thought I remember it was hard enough to source at the time, 2020-2021, again with the sealant , I just can't remember without looking back over paperwork, but again it was either mb dealer/ or what wavetrac recommend.
I've pics from it being done with all the paperwork etc I can share if it helps
Cheers
Motul GEAR Competition 75W-140 Racing Fully Synthetic Car Gearbox & Limited Slip Diff (LSD) Oil - 1 Litre x 2
This is the seals from mb, one used in the pic , two fitted rebuilding, mechanic told they didn't need replacing tho best to replace when you have at that stage for peace of mine
Hi there
Cheers
Stil looking back on my phone of pics when mine was done, both drive seals I replaced both are the same part numbers , the other seal was for the front of the diff from the main drive shaft ( seal ring)
Attachments​
I got 2 of them.. agree best to while there
Attachments​
I was looking at the front seal - called the pinion shaft seal i believe. The diff's typically come with the two output shaft seals and not the front pinion seal. Looking at the drawings I am not sure the front pinion seal gets disturbed. It looks like it gets dis-attached from the prop shaft further up and not where the front seal is fitted... I havent bought one of these for that reason. Not sure if anyone can confirm my understanding is correct or not?
Hi there
Cheers
Thanks for all the info @Barrymckenna. I havent had a diff fitted yet, its sitting in my office. However i decided to go for a Quaife in the end. Mainly because i got it for £910 Inc delivery & VAT (inc 2 seals also). The cheapest Wavetrac without the 2 seals was £1160. If the price was the same - id have gone for wavetrac. However given the price diff (forgive the pun) and the fact that there is hardly any difference between the 2 diffs on the road, it was an easy choice. I am not interested in tracking the car and getting a wheel up over curbs. My 507 is too nice and the thought of treating it that way doesnt appeal. Its not a C63 BS or a McLaren 720 so I respect what it is and what its not. That was my logic on the diff choice. Looking forward to having my install done soon.
For anyone interested i got my Quaife from Matt Lewis racing. There was an offer on and i also got a additional discount code for an extra 10%. My Indy specialist could been that price even with his trade discount applied.
My mechanic didn't replace the front seal because of this reason above, just checked a box with the original diff in it and realised the pinion seal was still there and not used at the time.
Exactly my thought too
