Cabin fan blower fluctuating. Viano 2012 3.0.
Number1
Uk
Viano
Hi , on any setting on fan control. The fan will blow then die then blow then die etc.
Would this be the fan motor on its way out or the resistor.?
If just the resistor I will only replace that if it's the motor I will replace both.
Also if it is the above. Are the parts on ebay with 10 year guarantee any good? Or better to replace with merc parts.?
What's anyone's thoughts on the problem?
Or is there something else it could be? Does it regardless of A/C on or off etc.
Thank you in advance for any advice.
