Car won't start
Graham2414
Germany
C220 170ps diesel estate
Hi my name is Graham,
I recently purchased a MB220 CDI 2011 model. 207,000miles, 170ps, 2.2ltr diesel, estate avant-garde automatic. Well I went to my local chemist parked up. Returned to the car attempted to start, crank no start. No warning lights or messages prior to and after parking. Anyone any ideas what the fault may be???
Appreciate any help 🙏 💯
Many possibilities
Crankshaft position sensor, Camshaft position sensor 6, failed low or high pressure fuel pump.....
Garage has checked timing- OK. Fitted two different cam sensors- error code still showing. Error codes showing at the moment
PO34100
P200A28
P262700
P200A78
P2A0064
From what I have analysed so far none of these failure codes with exception of the first should stop the car from starting, or am I totally wrong??? The garage is now saying it could be ECU??. Is it advisable to repair, clone or go for new. Any ones help greatly appreciated 🙏 🙂
What sort of garage? MB specialist?
I've seen a lot of mercedes being repaired there. Car is mb c220cdi, 2010, 170ps, W204
OK, that doesn't mean they are an MB specialist. Do you know if they used Star?
