upnorth62
Stop/Start hasn't worked properly for some time now and I've had problems starting it recently.
Had to get the neighbor to jump start it once, it fired up instantly so I don't think it's an alternator problem.
Also getting a warning about auxiliary battery failure which which is disabling the brake hold.
Looks like main battery is the original MB battery so it's over nine years old.
So, I've seen the KillerHertz vid for changing the battery, which seems straightforward, but I'm a bit concerned about maintaining voltage.
I'm assuming that the auxiliary battery will keep enough power on while I swap the main battery out but if I'm getting warnings about auxiliary battery failure then am I putting myself at risk of losing settings, or worse?
