billywhiz
- Dec 28, 2010
- E55
Unsure of all the screws.. may get it refitted in a surround
Get rid of the screws, drill out the captive nuts, get a new plate made and stick on with double sided tape without a surround. Less is more
Don't forget to stick some tape over the holes where the studs were.
Yeah mine are all glued down with double-sided sticky foam now. Looks a lot cleaner.
i need to do this , i just dont seem to find time..
No need to drill them out
Just take out the screws , bin the plate and get a new one made.
Get your surround ( they have recessed parts that the bolts sit in ) ... use the screws that you took out before and use them to hold the surround on.
Get your sticky pads , degrease the plate and the parts of the surround that they will stick to.
Stick on them onto the surround , peel off the other side , stick on numberplate , bolts hidden under plate , job done.
No , the plate surround i have has a lip that sits tight against the lid , the captive nuts sit within it.
Cost me all of £5 off ebay.
Ahh, I see. But if you don't want a surround you will have to drill them out. Anyhow, usually at least one of the screws shears off if the plate has been on a long time because of the alloy captive nut corroding.
Seems I am again going to be a lone voice in favour of the authentic four-screws-per-plate that separates a Mercedes-Benz from the rabble.
Surely that number plate wasn't actually made up by Hughes, was it? If so, they've done you no favours by placing the characters too high - they should fit between the upper and lower screws, so I'd ask for a new set or my money back. I've also never seen a Hughes fit a lipped plate before; must be a recent innovation.
Oh, and as for the question posed in the title of this thread: do you really need to ask...
