Checking sticking turbo vanes - recommendation in Cambridge
AndreiB
Cambridge
C220cdi
I’m after a recommendation.
Do you know someone within reasonable reach from Cambridge who can have a look at the turbo on my Merc (C220cd)?
Specifically I need someone to check if turbo vanes aren’t sticking. Many thanks for your help!
So does it mean the vanes can’t stick?
The car is overboosting and the turbo cuts out when I floor it in 2nd or 3rd gear. But it only happens between 2 and 3 K rpm AND only if I apply full throttle before 2k rpm. If I floor it at 2.5k rpm it revs freely.
Had the boost pipes checked, and replaced the boost sensor and the EGR valve.
The vanes are fixed.
Google for OM651.pdf to find a full description.
