ivandraganov
- Jul 15, 2008
Chirping sound when idle.Is that beginning of the end?Help!!
alternator pulley.
martyz said:You or your car?
grumpyoldgit said:When you say sheared off, has it damaged the shaft? I believe replacement pulleys are available, or if it is toast you could try a breakers.
What car is it for?
Dieselman said:Why abort the overtake and did you lose lights and steering?
The thing that worries me whether will be hard to remove the piece of the pulley which is still attached in order to replace it.
