lostinthesticks
Hello, I'm new to the forum and hope someone has some advice on what I could try now. I have owned the car for around 13 years.
I have had the problem for 6+ months (I drive conservatively so may well have been there before) sometimes when using full throttle, when the engine is up to temperature, and at the moment of kick down, the engine cuts out, engine light on. Every time it starts back up on the key, after shifting to neutral, usually well before I have coasted to a stop.
I have done some work over the last 6 months around the fuel system (had the seals changed on the HP fuel pump (fixed the leak) changed fuel filter, changed plastic fuel lines (fixed intermittent non start) fitted Injector leak off repair kit (fixed leaks) Changed fuel pressure regulator - this was just guessing really.
I am now thinking the problem may well be completely unrelated to fuel, although most of the repairs were needed anyway. Any help much appreciated.
