CLK 280 lowered springs
krotov71
West London
A209 cabrio
Hi guys. Want to lower my cabriolet I bought recently. I read online that the some springs like H&R make rear a bit lower then front ( see picture). I will go to Eibach as usual but doubt still exist. Do you have some advise or even picture of you car lowered pls. Thanks
Depending on the spec of your 209 the ride height can be altered by using a combination of shorter springs and thinner shim pads. I have a virtually new pair of AMG line rear springs and shim pads for a 209 for sale. They are genuine MB, the biggest drop you can get would be 30mm, but again this depends on the current set up. If you already have the sport suspension you will not get 30mm drop by using Eibach springs. I have a Bilstein and Eibach combination on my 209.
