Edmoody182
- Nov 19, 2023
- 2015 CLS 350 AMG LINE
Hi all, recently purchased a 2015 CLS 350 AMG line from a garage london way, (3.5 hour drive from home)
Was made aware that the o/s headlamp unit had moisture inside the lens upon purchase, when going to collect I had a closer look and it seems as though the unit has been messed about with and I said I’d like a new unit sent to me. Which they agreed. It hasn’t been sent yet, and the current one was working ok-ish, had the intermittent fault saying that the intelligent lighting had a fault, however all lights worked so all good for now.
Last night the o/s indicator, dipped beam gave up, and it says on screen that the n/s turn signal is failing too, however it does still work.
Would these problems be caused by the control module taking on moisture from the unsealed unit? And whats the best route to take regarding this.
