clutch and flywheel w124
PeterClark
1992 W124 200e manual
Hi I'm have a 1992 w124 200e manual and I think the clutch is starting to go so I was wondering are all the clutches and flywheels the same on all of the manual w124 or do they differ also are they a duel mass and if so does any one do a single mass conversation any help would be appreciated
Peter
I doubt that you will be finding a dual mass flywheel on a 1992 petrol-engined car.
Peter
On that age you could have either a dual mass or solid flywheel setup, there isn't a conversion kit to replace the daulmass flywheel. However you can convert from one setup to another as long as you change the gearbox at the same time (the input shaft's are differing lengths).
As for the flywheels, you will need one from an early 4 cyl petrol w124, or w201. Although others will fit, they dont have the correct pick up points for the ecu.
