Codes P0300, P0301, & P0303 etc... HELP!!!
LasVegas
Las vegas
W202 2000 C230.
have a 2000 c230 Kompressor (W202). It has 175,000 miles.
I was passing a car yesterday and gave it some gas to get by and the check Engine light came on. It drove very rough and badly after the Check Engine light came on. I got it home and checked the codes. There was one code, P0301.
I did a compression check:
Cylinder 1 psi: 160 & 155
Cylinder 2 psi: 130 & 135
Cylinder 3 psi: 160 & 160
Cylinder 4 psi: 120 & 120
I then installed new spark plugs and spark plug wires (I had bought some a month back, hadn’t installed them yet).
I then changed the places of the two coils. I put #1 & #2 coil where coil #3 & #4 was, and vice versa.
Now I have five new Check Engine codes: P0300, P0301, P0303, P0300 P, & P0301 P.
Anyone have any advice or answers. Thanks in advance.
Vegas
Welcome to the forum, first of all I would not be happy with the compressions on pots 2 and 4, they are a bit low. How did you do the compression test? are the second figures after you had squirted a drop of oil down the plug holes? If so I would think its head off time and get the valves sorted out, and measure the play at the top of the piston.
Your P0300 codes are for a cylinder misfire 1 and 3, but if you have swapped the coil packs around then they would have been for 2 and 4, I presume. It seems that both coil packs are faulty and need changing.
With 175,000 miles on the clock, perhaps the engine is getting a bit tired and needs pulling down and a set of new rings and the head done, and it may then last another 175,000 miles.
Steve
So an update.
When I swapped the coil packs it triggered more Check Engine codes. My guess was the coils were bad. I bought two new coil packs from Autohausaz, installed them and my C230 is running well again. Problem solved.
Thanks for everyone that responded
Thanks for coming back and reporting on your positive outcome.
Steve.
