dazblink
I'm getting the following codes and the EML comes on about 3 or 4 journeys after clearing codes.
P208027 - Temperature sensor 1 Exhaust sytem (cylinder bank 1) has a malfunction. The signal change rate is above the permissible limit value
P200A75 - The charge movement flap (cylinder bank 1) has a malfunction. The emergency position was not reached
I fitted a new temperature sensor but still get the code. The sensor I bought was a cheap one that i found on ebay - less than half the price of a genuine one. Could be that its a crappy sensor but thought i'd get your opinions before swapping it again for a genuine one.
The other code i don't know much about other than my mate saying I would need a very costly new manifold? Although he did say something about having it re mapped with the code deleted so the ecu doesn't detect a problem? What are your thoughts on this?
Is there anyway at all the 2 codes could be linked?
