Comand identification 2011 W204 C200
baff57
Norwich
Mercedes W204 C200 2011
I have a W204 C200 purchased 14/03/2011 , it has a 6 cd changer,Becker sat nav, Bluetooth Phone connect.
What i am trying to identify on whether it is a NTG4.5, NTG4.0 or Audio 20 so i can try and install an Android system. It seems the unit looks like the 4.5 but because of the date unlikely as it does not have the SD card slot in the front. The 4.0 has a small chrome strip that is missing and it has a 6cd Changer as well.
Is there anyway of positively identifying as don't want to order the wrong parts.
Many thanks in anticipation
Best Regards
david
Audio20 NTG4.5.
Although... 'NTG4.5' is often used to describe 'COMAND NTG4.5', so using the term NTG4.5 in relation to Audio20 can be misleading (although technically correct).
In this case, it would best if you referred to the system as 'Audio20'.
The COMAND unit for your car would have an internal hard disk drive, an SD-Card slot, larger high-resolutuon screen, and built-in navigation.
Ok, that has been so helpful and many thanks .
