Zenbasses
If I open or lock the car and hold either key fob then nothing happens. I checked the owners manual to make sure there wasn't some wizardry that was at play but it is as I expected
I've replaced the C batteries in both remotes, still nothing ...is it hidden somewhere in a menu I haven't found yet ???
Tried all windows closed
All windows open (manually)
Windows half way down
Panoroof open
Still no luck they just stay put
I have got the annoying feature where my passenger window will roll up using the window switch and then instantly open again
I've reset it twice but it keeps reoccurring....and it's highly annoying for my partner...hahab
WARNINGRisk of entrapment when opening a side window
Press and hold the
button on the key.
The following functions are performed:
To continue the opening procedure:
press the
button again.
To interrupt convenience opening:
release the
button.
Panoroof open
- E-Class
- Estate
- 2017
Press and hold the
- The vehicle is unlocked.
- The side windows are opened.
- The sliding sunroof is opened.
- The panoramic sliding sunroof is opened.
- The seat ventilation of the driver's seat is switched on.
press the
release the
