Hi all,
Just joined club and hoping for advice on coolant leak which has just started on wife’s 1985 280SL with 110.990 twin ohc.
Car been laid up for few years, although have occasionally started and not had issues until last week when noticed no coolant in heater tank.
When adding coolant it is leaking somewhere under the inlet manifold near the front of the engine but there are so many hoses etc there I have not been able to spot where the leak originates ! Tried looking from above, underneath and from side but with no luck.
Local classic car mechanic suggested core plugs but has plates not plugs and I think they are on the exhaust side of the block.
I am hoping someone knows if there are any coolant pipes or hoses in that area ?
It might be the head gasket but seems surprising that gone from no leak with engine running to leaking when just topping up the coolant !
No other signs of head gasket related problems.
All thoughts and advice would be most welcome
