190 pet, 2.00, man
for some time now I have had no heat from the heater assuming it was blocked I thought an investigation would be in order, I found the fan motor to be a bit dodgy so replaced it, but knew that this had nothing to do with heat comming into the heater martix, I think we all know of this nightmare job to replace the matrix so thought I would flush it out, reversed flush, rad flushers, acitic acid etc, re-assembled still the same , I am know thinking that instead of a matrix I had a block of sludge, so left it , I then had this idea (good or bad ) to use a wall paper steamer to flush the matrix and to my suprise with steamer running I had so much heat comming from my heater I could not keep my hand there, this got me thinking , this was so hot that should the windscreen have had a shower of snow on ice there would be a risk of the screen cracking, so is the water restricted somwhere, or the heat controlled some how as I am now of the opinion that there may not be enough water flow, I have checked all visible pipe work hose'es etc for blockage all ok, fitted new water pump & stat 5 months back. one thing I have noticed that the cooling on the car seems to be ultra efficient temp always just below mid point unless car is idel any advice welcome
