Couple of problems.
MattyBass
Herford, Germany
W124 E230
Hello.
My car failed it's German MOT for a couple of lighting problems, and was wondering if anyone can shed any light (no pun intended) on them before i attempt to use my schoolboy german at the local Merc dealer.
The drivers side headlamp is really dim compared to the other one, and after changing the bulb and checking the wiring it's still dim.
Other problem is the drivers side side repeater, it doesn't work at all. Again i've tried new bulbs and checked the fuses, but still nothing. I wanted to check the wiring but i'm not sure where it is connected up inside the car.
Any help will be much appreciated. :thumb:
Sounds like you have a bad earth somewhere...
