DAB Ariel fitting
Sedatev8
Yorkshire
B180 Sport
Hello,
I'm fitting an aftermarket DAB device so I need to remove the A post trim panel from my 2015 B180 to fit a DAB Ariel and run the cable, worry part is the airbag, can anyone tell me how its done please?
Regards
Lee
Hello,
Regards
Lee
YouTube and Google are your friend for this one.
Hello,
Regards
Lee
Use a Plastic Tool to carefully prize out/remove the Airbag Signed Cover, underneath you will see two Metal Tangs that the Airbag Signed Cover kept in place, using Long Nosed Pliers, pinch the Tangs partially together and carefully Pull the Metal Bracket Free from the Airbag/A Post Cover, the Cover should then be able to be Removed! ;)
Replace in Reverse Order! :rolleyes:
Thanks John !
