Baldbloke
I have an issue with my rear self levelling air suspension and need some clarity on why my 2007 Elegance estate car might be so different to the other trim specced estate cars that the Arnott spring conversion set up won't work.
C-3080
Arnott Rear Coil Conversion Kit - 02-09 Mercedes-Benz E-Class Wagon (W211) w/o ADS
Supposedly the spring conversion kit works on any 211 with rear self levelling suspension as long as it doesn't have ADS. I presume ADS is air suspension on all four corners. My car just has the self levelling air suspension to the rear with the front having springs, so it seems to fit the requirements listed in the kit above. However, Arnott has suggested that their kit will fit every model of 211 estate car but the Elegance.Here's a description on Ebay:
Item Description
Arnott Rear Coil Conversion Kit - 02-09 Mercedes-Benz E-Class (W211) w/o ADS w/ Rear Suspension
Arnott's new Mercedes-Benz E-Class Wagon Coil Spring Conversion Kit was exclusively designed for the E-Class Wagon with rear air suspension only (without ADS and excl. the Elegance models!!). This kit converts the rear air springs of the vehicle to a reliable coil spring suspension system. Arnott's springs are designed to give your wagon a smooth ride, comparable to the original air suspension. These aftermarket springs fit perfectly in the seat without welding or modifying the original suspension. The Mercedes-Benz E-Class suspension Conversion Kit features powder-coated coil springs and detailed installation instructions including how to turn off the dash warning lights.
Features:
This rear Coil Conversion Kit is not for E-Class Wagons with 4-Corner air suspension (w/ADS) and NOT AVAILABLE for ELEGANCE models.
Additional Information: This part number replaces C-2675.
Fits Vehicle: 2002-2009 Mercedes-Benz E-Class (W211 estate w/Rear Leveling Only w/o ADS)
Can someone please tell me how my rear suspension differs from say the Avantguard model of E-Class 211 Estate car, and why the kit shouldn't fit?
C-3080
Item Description
Features:
- Converts E-Class with Rear Air Suspension Only
- Powder-Coated Steel Springs
- Fits Without Modifications
- Detailed Installation Manual Available
- Arnott Superior Warranties
