Hi. I've just recently bought a 2006 Merc E280 3.0 V6. Having a few issuses with the DPF. When Im accelerating from stand still and give the car some throtle it starts to judder and on some occassions goes into limp mode. When I turn the car off and fire it up again the problem goes.
It seems to happen when the car is cold, but recently its started doing it when the engine is warm. I've had the codes read and its is coming up with a fault but no engine management light. Now I don't do many motorway miles and I've been told the car needs to be put through its paces so the filter doesnt clog up.
Because I do a lot local driving (short journeys) is it worth having the DPF removed altogether to eliminate this problem. I dont really fancy paying £1100 for a new DPF fitted.
Was wandering if any one else has had this problem and how you rectified it.
I look forward to any help I can get. THANKS
