city lights
Is durability affected by displacement? And if it isn't anymore until which year was it supposed to be? I guess durability of 2.2 liter engine from 2008. containing 200 hp is not affected by the size of displacement but what about the engines from the beginning of 2000s?
Some say that if there's 'a lot of HP on small displacement' the engine's more likely to weaken it's durability.
Talking about the engines, I got C200 CDI from 2001. with 6M gear shifter and I wanted you to compare it to C220, 270 and C320 CDI from the same period, or any other petrol from W203 series. Which one do you think has proven to be the most durable and which one of the mentioned diesel (or petrol) engines would you recommend?
The one I got has 116 PS and it is quite good, but at some points it doesn't deliver as much power as it takes to 'glue' you to the seat, unless you drive at 3000rpm in the 3rd gear. It seems to have lack of that kind of power while driving in the 2nd, even if it is at 3000rpm.
I would also like to know how more stabile is W203 C 320 CDI 4 MATIC, considering the 4 wheel motion system?
