MercedesintheBlood
Hello All
Is it ok to use E10 fuel in a 2005 CLK 320 w209 ?
TIA
TIA
E10 should be fine, but if you’re concerned then stick to E5 which will most likely be Super Unleaded. Some people report a reduction in fuel economy (ie an increase in fuel consumption) when using E10 in which case the cost premium of using Ser Unleaded may be reduced.Hello All
TIA
E10 is more deliquescent than E5 due to its greater alcohol content- not an issue for a car in daily use - but not a fuel for a car likely to stand idle for several months on end in a damp environment/climate.
