E220 antenna
scirocco
Hi, I need to know what antenna the E220 from 1994 uses? The Auta 6000KE F-11?
Does anyone know if the Hirschmann Auta 600KE F-474 and the 6000KE F-10 are the same thing? the former has a W202 part number while the latter i presume is a generic Hirshmann part.
Can't say for definite but, on the "button" on top of the antenna mast is a code - H4 on mine, pop into your local MB dealers they should be able to tell you which antenna is fitted.
I just replaced the telescopic mast on mine, the motor unit was fine - £19 from the dealer.
Hi - am new user and this is my first thread.
I recently purchased a '94 E220 coupe and have to replace the antenna. The motor seems fine, it's just not extending or retracting correctly.
I can't find a good reference book for this model. Haynes don't cover it.
Can anyone recommend a good manual?
