E280 front suspension rattle
Lancelot
W124 E280
My W124 has started to have a rattle that seems to be coming from the driver side from suspension. Could anyone tell me what could this be? The car is a W124 E280 1995. just 71,000 miles from new.
The correct word is creaking, not rattle. I have been told it is probably moisture in the bearings. Any thoughts are much appreciated.
when does it happen ? turning slowly or going over bumps ? etc etc
Unless you have a broken spring its probably one of the bushes that has worn out. Best to replace them all. You will be amazed what a difference it makes to the feel/handling.
Dry bottom ball joints can also give this problem in my experience, I just had to replace them to confirm it.
