e300 indercator relay WHERE IS IT?????
katier1988
mercedes e300
hi ive got a 95 e300 with an intermittent indercator problem?? ive replaced the whole indercator stork still same problem?? I can not locate the relay tht controls the turning signal :fail can somebody please point me in the right direction please
Welcome to the forum.
The indicator functions are controled by the light control relay, this is found in the rear of the fusebox and is the largest relay in there.
Check your fuses.
Those torpedo fuses can break in the middle, with the ends just making contact.
Remove the fuse and check the element at its thinnest point.
cheers will check these 2moro :) altho I have had a poke around and cant see anything big enough in the fuse box tht seems obvious to the eye??
undo the 4 screws on the fusebox and release the lid so the back of the fusebox comes away. the relay is a large long black one inside:
thanks for the pic shame its not what mine looks like mines a 95 aventguard twin round headlight model fusebox is in the same place but houses only fuses and a n65 module which is the diesel ecu and then just a big hole in to the bulkhead with lots of wires but no relays im stumpted cheers
