kevin288
Hi I am new to site.
E320 water in the boot 2009 saloon. So the carpet is bone dry and all the boot interior panels are dry but in the base of the boot under the spare wheel is standing water. I dried it out and poured seven or eight watering cans over the backend of the car still no water in the bottom of the boot so I drove to my local car wash prior to spraying it I checked the boot and low and behold now there was water there! I've sat in the boot with the interior panels missing and there was a slight weep through the drivers side rear light unit I have cleaned and petroleum jelly and rebuilt there are also two vents flaps to the right and the left hand side lower rear quarter panel looks like a slight bit of water might be getting through there but doesn't seem to be leaking badly enough to create what is sometimes a pint or two of water in the boot. It couldn't be the boot lid seal because the carpet would be wet and it couldn't be the brake light in the boot lid because once again the carpet will be wet. I have tipped water carefully down the fuel overflow pipe but as quick as I am pouring it in I can see it's running out under the back of the car so I can't imagine this is leaking within the boot. Any other areas I need t be looking at? I am leaving the wheel and the carpet and the interior panels out of the boot until I have solve the problem. Thank you in advance if you can help
