Transalpir
Hi All
I'm new to forums and have a tricky problem try this with...
i have a 2000 facelift E320cdi while towing a 750kg trailer n load Ihear a strange rattling noise like metal shooting down the exaust? Engine seems unaffected apart from a knocking that seems to come from the top end.
I took out the injectors and stiped it down to the hydrolic lifters. found that no9 inlet had been scraping and had deep scores init put a new one in after testing the valve spring ( comparing force required to open it with the others). reasembled and took car for a drive...no change
I have now bitten the bullet and removed the head to see whats what. Iexpected valve seat issues but they seem fine on initial inspection, but will remove and regrind/stem seals while I can.
In the bottom end I found that no5 cylinder has some abnormal scoring to it so needs out, but how. the engine is in car and the sump has to come off!
Seems that the subframe may need to come out ? Anybody got any hints and tips please?
