Roger57
- Sep 10, 2014
- Location
- Bolton
- 2011 E350 Estate, 2011 A180, 2006 A180, 1973 VW 1303
Good morning everybody,
My 2011 E350 needs attention. I have had to have the O/S rear tyre replaced because the tyre was worn down to the casing on the inside if the tyre. After replacing the tyre I had a four wheel alignment check and the report shows that the toe adjustment at the rear is not within spec. This adjustment is carried out using the usual eccentric bolt/washer system (last saw that on my 1973 VW 1303) which moves the lower suspension arm in and out to adjust the toe.
Problem is that the bolts are heavily corroded and the technician didnt want to attempt the adjustment in case one or both of them sheared. There may also be an issue with removing them because of the position of various parts of the cars underside; looks like they will have to be cut and removed that way. And then of course there is the possibility that the bolts are actually corroded into the bush......hohum, eh.
So I will need a pair of replacement bolts at least to start with. If anybody has done this job before, are the adjustment bolts readily available or are they MB dealer parts only?
I would appreciate any assistance at all, please.
Regards
Steven
Regards
Steven
