Shown on a w211 here, but it’s exactly that on the lower arms. Nice findView attachment 164028
What Jobsworth said post #7 in picture form. They call it a crash bolt in the USA , I suppose once a pranged car is kicked straight and re sprayed the slotted bolt gives the repairer some leeway when setting the alignment.
The bolts are widely available and easy to change. A slotted bolt will easily take care of the 0.57' you need .
Iv done them (twice) on my C55 , my car has non slotted bolts , I just put them back in the same place both times , no issues. I do have slotted bolts in stock , bought 'just in case' .Shown on a w211 here, but it’s exactly that on the lower arms. Nice find
However, having just looked this up, it appears from what people say online that toe does not and can not cause pull - whoopsI actually doubt it's much to do with caster or camber, as the values are little different to what they were when it was in its original state.
Cheers Phil, I'm hoping that will cure it but 99% sure it won't - as the wheels with these tyres were on the rear before, with all seasons on the front, and the pull was the same. I'll do it all the same to rule it out though, I'm all for the scientific approachQuick point: try swapping wheels left to right just to make sure its not that. I had a W203 and it turned out that one tyres must have had an internal fault (perhaps a radial belt snapped) and the peculiar rolling resistance on that side made it pull... new tyres fixed it.
oh yeah don't get me wrong, I've read all the way through that - the fella from WIM states repeatedly that excessive left pull with camber can be sorted. It must be fixable, as (as I've kept repeating) my car did not used to do it until I had KwikFit do the alignment. I don't have the slotted bolts either, so while I'm willing to splash out on them to fix the issue, I don't feel that it should be necessary!Nobody yet mentioned the Wheels inmotion thread which had something definitive to say about pulling to the left.
Definative explination.... Pull left | Wheels, Tyres, Brakes & Suspension
You do know your not meant to mix all season tyres with summers . ?oh yeah don't get me wrong, I've read all the way through that - the fella from WIM states repeatedly that excessive left pull with camber can be sorted. It must be fixable, as (as I've kept repeating) my car did not used to do it until I had KwikFit do the alignment. I don't have the slotted bolts either, so while I'm willing to splash out on them to fix the issue, I don't feel that it should be necessary!
several people have been kind enough to tell me that, but that's not what we're talking about here is it? Never mind the fact that after getting them fitted it didn't pull, that started after alignment! and never mind the fact various garages and mechanics have told me it's not a big deal....You do know your not meant to mix all season tyres with summers . ?
