Mondayo
There's a nice bit of discount on Autodoc today....I'm after some new plugs for my S211 E55.
What are the best ones I should go for?
Those are the same plugs I put in on my previous E55.I bought the plugs for my S211, E55k from the parts counter in my local MB as per vin no.
They where NGK ILFR6A and a good price too.
Advancing the ignition timing can help an engine to produce more power but can lead to knock or preignition, which is not good for the health or life or the engine.What improves if I install one step colder plugs versus recommended plugs for the car?
I get better what???
Spark plug charts tells you what product number plug is recommended for each model.
Charts do they also list colder plugs suitable for specific cars?
I’m not sure to be honest. I bought the car with it all upgraded and tuned and the previous owner stated that I can’t just put the factory spec plugs in due to the upgrades and power it’s running currently. My W211 E55K is running 600bhp with 700ftlb. Sounds like the original spec plugs will run too hot causing issues.Perhaps colder plugs are more suitable for turbo and supercharged engines not for NA engines?
I suppose there's no advantage for NA engines using one step colder plugs?
what's mods is it running?I’m not sure to be honest. I bought the car with it all upgraded and tuned and the previous owner stated that I can’t just put the factory spec plugs in due to the upgrades and power it’s running currently. My W211 E55K is running 600bhp with 700ftlb. Sounds like the original spec plugs will run too hot causing issues.
Interesting.what's mods is it running?
fyi ; - on my e55 even with pulley map, headers etc standard plugs were fine, you can run one step colder plugs, but never had to, even with my e63 running 900+brake standard plugs were fine.
Not necessary to remap for a change of plugs.If I can run standard plugs, I would be more than happy to. Also if I switched to standard plugs would I need to get the map redone?
Hi MazInteresting.
I’ve got pulley, map, long tube headers, throttle body, heat exchanger, split cooling, belt wrap kit.
