- Mar 11, 2013
- Location
- South Bucks
- CLS63 SB, ML63, CLK350 'Vert, Triumph Sprint (Bike not Dolly...),
My previous thread on this topic sets the scene: E63 5.5 TT Misfire
A quick recap:
The initial problem was an intermittent ragged misfire under hard acceleration at high revs. Most of the time it did not occur under the same conditions.
There was oil at all four camshaft position sensor connectors, and at the ECU connector, so there was (and still will be) oil in the main engine wiring loom.
The plugs had done 40K miles, so I fitted new ones.
I'm using an iCarsoft MBII as a diagnostic tool. The previous set of trouble codes (with the new plugs in) was for misfires on 5, 6 and 8. I fitted new (genuine MB) coils and leads on cylinders 5, 6 and 8.
I fitted four new (genuine MB) camshaft position sensors, and cleaned up/out (lots of contact cleaner, blow dry with an airline) all the oil at the camshaft position sensor and ECU connectors. It ran fine, pulled as it should, misfire gone, all in the garden was rosy......
Until today. I took it out, "Warp Factor Nine Mr Sulu", and the misfire is back. God, I hate intermittent faults!
It's a little different, though; the misfire was not ragged, but a single thump, something like I imagine the rev limiter kicking in might be, and it went straight into a sort of limp home mode - runs okay on minimal throttle, misfires on anything more, and misfires at idle.
The trouble codes are a little different, too. I drove home, switched off, plugged in the MB II, and now had misfires on 1, 5 and 8, all stored codes only.
There was no oil at the ECU connector.
I left the MB II plugged in, started the engine, ran the diagnostic, and now I had codes for:
Misfires on 1, 5 and 8 - all stored;
Stored code P069704 - "Output 3 for reference voltage of sensors electrical fault or open circuit. There is an internal fault".
Stored code P007012 - "Charge air temperature sensor cylinder bank 1 short circuit to ground. Short circuit to positive."
I left the MB II plugged in and took the car for a little run. It ran perfectly. One new, current, code appeared - P026A00 - "Charge cooling insufficient". There's a tear in the flexible inlet hose for cylinder bank one, which may account for that.
I can't find a decode anywhere for P069704. Does anybody know what it means? (Please God, not the nuclear - for the credit card - option, a new ECU...)
A quick recap:
