Hi guys unfortunately my unlucky run continues with the recently purchased E63 I have just had the MOT done and it has picked up on a serious seized drivers side front calliper. The pad is worn completely down on one side and the wheel is solid and won’t move and is obviously extremely hot compared to the other side. He said if that was any normal powered car it simply wouldn't move and it’s only because of the power that the car has that it drives which is crazy
Whats really annoying is that it was only in Mercedes last Friday for a diagnostic session and to look at a few niggles that I wanted investigating before the warranty expires in a few weeks time. They took it for a drive and did a visual inspection and found no faults and said it’s fine and the juddering was the characteristics of the AMG range
So my options are I’m assuming is a calliper rebuild and maybe new discs and pads depending on the damage once taken off the car
Would anyone have any recommendations on who to use to have them rebuilt as I’d probably do the full set while off the road ?
I also have 3 weeks of the Mercedes AMG extended warranty remaining what’s my chances of this issue actually being covered or am I living in a dream world to expect any help ?
Has anyone used the Mercedes extended warranty before for a calliper issue like this ? The garage today stated that Mercedes can’t really use the fair wear and tear example as the passenger side and rears are perfect. It’s only because of the seized calliper which has caused the issue
The car also has a full Mercedes Benz dealership service history if that makes any difference and it only had the the brake fluid changed in the last few months with everything fully up to date
The car is currently booked into Mercedes next Wednesday to have the air conditioning leak tested to see if the warranty will cover it or if its stone damage this alone is costing me £245 which I won’t have to pay if it’s a genuine condenser fault but what’s the actual chances of that happening But they stated when I bring it in on Wednesday and if the juddering continues then to mention it and they will further investigate but we obviously now know the reason why it’s juddering.
Fingers crossed the calliper and condenser will both be covered but I’m seriously not holding my breath and expecting a nice big bill so any help and advice would be very gratefully received thank you
