Hi guys I unfortunately had my first issue today in the new to me 2015 E63 that I purchased just over a month ago, after a little drive this morning to the library to print off a label I experienced my first scare
I came back to the car started her up and instantly it sounded really rough and louder than normal it was also idling really bad I drove off slowly to try and get it home and the whole way it was down on power and then the dreaded light of doom appeared
I managed to nurse it home and called Mercedes to make use of the included Mobilo breakdown service who I must say were absolutely brilliant and they couldn’t do enough to help me
They originally stated that they use the RAC for breakdowns etc and a patrol would be with me soon, but 30 mins later I received a call from Mercedes to say that because of what car it is they don’t feel that the RAC are best equipped to help me and instead would now be sending out one of their own Mercedes specialist Technicians to assess the car
They arrived a hour later fully equipped with the same diagnostic equipment that the dealership use and instantly plugged it in to find that 6 codes were stored. He stated that the stored codes are showing now as not being a current issue but went ahead and removed all codes and the light. The main code stored was listed as coil pack 1 but with it now not showing as a current fault and after removing the codes he asked me to take it for a 3 mile drive to see how it performed
The car was actually now running even better than before I can’t believe it even the really harsh juddering that i seemed to have when using sport plus mode for instance when just driving normally in the street that Mercedes told me was just the characteristics of the e63 has now completely disappeared and drives so smoothly in sport plus its a unbelievable difference he said it was probably all connected to the stored codes
He stated that the coil packs are not a common issue on the E63 and hopefully it would now be fine he also asked what fuel am I using as this can also affect the poor running I explained that the only fuel I use is Tesco 99 momentum he said to try and use shell v power if possible in the future but I don’t have any shell garage near me unfortunately would the 99 momentum really be a big issue ?
Has anyone with the e63 experienced issues with failing coil packs ? or had a issue like mine before ?
I’ve been out this evening and done around 40 miles and it hasn’t missed a beat it’s been amazing so a really bad start to the day has turned out to be a good one as I was expecting the car to be towed to the dealership so a big
to the Mobilo service I could not have asked for anything more
