Chrishazle
- Nov 13, 2008
- Location
- Nr Ashford, Kent
- 2008 S204 C220CDI Elegance Estate Auto, 2008 R171 facelift SLK280 Auto.
As if this week had not been bad enough already with the SLK, this morning I went to start the c220 - which had a good drive on Tuesday and was fine - starter gave small hiccup but did nothing, luckily still enough to open the doors and release (but not raise) the boot. Thought bugger, flat battery, so put charger on it, for about 10 seconds it started charging at 14 amps then dropped to 10 amps and stayed there. OK, battery is probably original, 11 1/2 years old and died, so searched and found a suitable alternative at Halfords. 4 hours on the charger and car started fine, drove completely normally to Halfords. They tested my original battery in situ, their tester showed it just needed charging, but I decided to replace it anyway. They connected a small battery to the OBD port under the steering wheel then changed the battery, car started fine, job done, time to go home - except the gearstick would not move from P!! Halfords manager took over.
Also noted that PRND light in bottom of speedometer was not working, C-S button did nothing, autofold wing mirrors not working when car locked - but brake lights work when brake pedal pressed. 2 hours and a further battery change later, autofold now working having operated the mirrors from the door switch but otherwise no change. Using the emergency release switch under the gearshift gater released the gearstick so gears could be engaged, so Halfords manager said take it to garage, find and fix problem, we'll pay!! OK, headed home.
That's when I found (car in C mode) gear change was not working, either automatically or trying to use the tip feature by pushing the stick towards me, so had to drive home I guess in 2nd at 30-40mph, 3-4K RPM! Nowhere open, so will have to wait until Monday to get it to my local indie - fortunately just a mile away rather than about 8 miles of busy road to MB Ashford!
Is it likely to be the brake switch, the selector module or what? Is there anything else I can try, ATM it's our only car so we're stuck until it's fixed!!
