I feel like new mounts improved in-cabin comfort but to a negligible degree. Probably because my original mounts were not blown, they were just a little collapsed. They lasted 92k miles, well done MB. I could potentially get 20k-30k miles out of them.Does your engine rock a lot less now they've been changed?
Thanks! I’ve had it for just under 4 years and I love it. It’s a car I rely on, I have driven it 40k miles since I bought it. It isn’t a weekend toy for me, it’s an everyday toy.Nice car! Looks identical to mine. How long have you had it and how are you finding it ?
At least your engine is in a more correct position now. My mounts are sunk too. Car has 80k so I'll be changing them soon. Is your rear subframe and brake lines looking okay ?
Looks to me like the engine can rock more now the mounts are done ? Or just looks that way after being woken up by a 3 year old on 5 hours sleep
Nice one, veteran owner! . I had a tranny service done recently on mine (I've only had it 2 months ) . The ride quality seems far less supple than my facelift 212 e63 s version that I had for 3 years, not sure if some shocks need to be replaced, or whether the performance pack on the early pre facelifts just rode that way or the nappa non dynamic seats on the facelift are just more comfortable. Still, it's not bad but just stiffer than I was expecting. I just had the subframe done under goodwill and forced the dealer I bought it from to take the hit on the brake lines.Thanks! I’ve had it for just under 4 years and I love it. It’s a car I rely on, I have driven it 40k miles since I bought it. It isn’t a weekend toy for me, it’s an everyday toy.
My rear subframe has been changed FOC by MB due to rust. I had renewed the rear brake lines few months before the subframe job, again due to rust. I also changed transmission pan due to same reason last year along with transmission mount as it was collapsed and mount bracket which was also corroded. There’s no other corrosion left under the car. Never had corrosion on the body. Based on my experience certain parts under this model are more susceptible to rust. Maybe they used substandard steel in this model because my W124 has never had any rust issues and pretty much lived in the same conditions.
Engine may seem like rocking even more than the first video because this time I really pressed the pedal. I was more gentle the last time.
Good result regarding the subframe and brake lines.Nice one, veteran owner! . I had a tranny service done recently on mine (I've only had it 2 months ) . The ride quality seems far less supple than my facelift 212 e63 s version that I had for 3 years, not sure if some shocks need to be replaced, or whether the performance pack on the early pre facelifts just rode that way or the nappa non dynamic seats on the facelift are just more comfortable. Still, it's not bad but just stiffer than I was expecting. I just had the subframe done under goodwill and forced the dealer I bought it from to take the hit on the brake lines.
I'm thinking all mounts next and fuel injectors. It's MOT runs out at the end of October. It's not my daily as my commute is only 10 minutes and I use my poor e93 M3 for that. And i definitely want to do something to the exhaust too
That's why I'll be changing my injectors just in case they decide to stick open and flood the engine.Good result regarding the subframe and brake lines.
I have not driven a facelift one before so I cannot compare the two. I would say the ride is not too harsh. Maybe get your suspension components checked and if anything is out the supplying dealer will hopefully cover the cost.
Regarding the injectors, I changed mine at 60k miles and they were carboned up despite using premium fuel only. They were not stuck open, I changed them as a preventative measure.
