sam3003
Hi there,
For the last year or so, I have been having a rattle when the engine started for a few seconds and then it went back to normal till the following morning.
This happens mostly in the morning on a cold start on my Mercedes c200 (160k mileage).
MB dealer noted : (extreme nosiy timing chair on start) in the Visual Health Check mid of last year.
When I took it to the indei and left it overnight for another issue, he said that the car started fine with no rattle. He however advised me to get it check if the rattle happens often/ or for a longer time.
I have read other posts for the same issue and one of the comments was: ((Change tensioner first, relatively easy job can be done with engine in situ. They are a bit of a weak point on these engines.
If noise still there, then chain can be changed once again with engine in situ. However, if the chain is badly worn then the chances are three sprockets will need replacing too.
The two camshaft sprockets are changeable with engine in place, but the third crank sprocket can only be changed with engine out ))
Do I need to insist on the indie to check the car again?
I am worried I might damage more parts which will cost me more to replace.
Another question please, is it true that it is better not to use the stop/start function as this kills the timing chain??
