Good evening everyone,
I am new here, so please be gentle. I apologise if the issues I raise have been posted before.
I have a 2001 E320 Avantgarde (W210). It recently stopped accelerating as it should, the kick down doesn't work and the engine will not rev over 3000rpm. I understand from a post I read on here it is possibly / likely to be the MAF sensor. I have ordered some cleaner to try that and if that doesn't work I will replace the sensor and see if that cures the issue. Could you please confirm if I am on the right track? Please note that every now and then it tries to kick back into life, usually after initial start up, but only briefly then back to the limited acceleration and rpm.
A second issue is that I purchased a RICOKEY Car OBD2 Scanner Universal Wired Auto Engine Fault Code Reader CAN Diagnostic Scan Tool V309
However, no matter what i do, I cannot get it to connect to / read the car. I thought maybe the one i had purchased was not compatible, so I purchased a
MOTOPOWER MP69033 OBD2 Scanner Universal Car Engine Fault Code Reader.
Unfortunately that has come up with the same issue and will not connect / read the car. I followed the instructions of turning the ignition on, selecting read codes and each time the reader tries to connect. However, every time it comes up with the message to wait 10 seconds and try again.
I know the port works, as the guy at the local garage has a basic reader and was able to read the codes previously. I though I would get a reader myself to save taking it up to him, but i must be doing something wrong, or the ones I have purchased are not compatible.
Any help or advice will be very much appreciated.
Andy
Andy
