Ovlov440
Hi all
Bit of an odd one but maybe someone has the knowledge.
Today, when calling on kickdown in my 2014 W218 CLS the car went into limp mode. This has happened before after which the Quantity Control Valve on the HPFP was replaced.
When I got to a set of lights I turned the engine off and non. The EML stayed lit (normal behaviour after throwing a code) but then the car also decided the parking brake was on, the bonnet was open and that it was dark (headlights came on). Drove home. I went out and hour later, no issues at all.
To add to the weirdness a couple of months ago I got the battery warning message on the dash. Having recently replaced the auxillary battery in the boot I replaced the main battery as it was reading 11.9v. With a new battery fitted I still kept getting the warning light for another 6 weeks, until it just stopped, that is until it flashed up 4 times yesterday!
I am thinking this is all related somehow so a junction box/SAM unit seems like a likely culprit?
A code read only shows P0087 relating to the EML.
Any thoughts/guidance appreciated.
Ade
Ade
