Checked flow to the EGR and from the EGR via the cooler and flows look fine. Have checked MAF sensors and compared with each other, reading are the same but negative readings at idle! Swirl flap motor changed and manifolds refurbished, throttle body, EGR valve, exhaust back pressure and MAP (inlet) sensors changed, fault persists both 14A700 and P0402 return even at idle after a few seconds of being cleared! I'm stumped, only other item I've not checked is the turbo actuator, just need to find a wiring diagram so I can check live values.
