Firstly, the OP does not state the car is not making the power he would expect; he states it runs fine.
And with regards to it running fine when warm, it runs great however you do notice that it is not pulling as strong as it should be. I had a c220d previously and that seemed to have more of a pull than this which is not right as this is a c250d.
THINK THE SUMP IS PLASTIC ON THE OM651?I have no idea how complicated your car is underneath , but removing the sump on many engines will give you some kind of a view up the cylinders . Even if accessible spotting a slight bend in a rod might be impossible.
Why not buy a diesel compression test kit? There are many on the market .Hi all, thanks for your replies. I think the main thing im trying to say is ive had a look at cars with slightly bent rods and how they sound and what the tell tell signs are and it just doesn’t seem to match mine. I know some of you have suggested that not all of the time u will get these signs but i just am struggling to come to terms with the fact the car is not displaying any obvious signs of internal engine damage surely this problem wouldnt go away when up to temp the car litterally sounds perfect when it is up to temperature not even the slightest knocking or misfire. Yes granted there is a problem with the power when it is up to temp but i have a strong feeling this is to do with the fact the dpf is full of soot and the nox issue. Furthermore i have had two new nox sensors already fitted but they are not reading anything. My guess is this will need updating which i will be doing straight away. As for the other problem I really am doing my best to locate a garage that actually does a physical compression test on this engine as i have had no luck so far called about 20 different garages. Some say the star xentry compression test is pretty accurate and some say its no good and needs a physical test. Im just starting to give up hope on this car at this point havent had much luck so far
I don't know what the Mercedes quoted specification is for compression on your engine (my previous gen E220d is 18bar/261psi minimum) , but generally speaking, you should have all 4 within 10% of each other. Remember that diesels rely *entirely* (glow plugs complicate slightly) on compression to heat the air in the cylinder and allow it to fire once diesel is injected. A lack of compression is almost certainly your misfire cause. I think the glow plugs are helping from stone cold, then when they extinguish, you experience the misfire.Hi everyone, just wanted to give you all an update in regards to my problems. I finally managed to get a compression test done and it turns out the compression in cylinder 2 is indeed low. Not sure what these numbers mean but if you guys can help it would be much appreciated. The figures i got on the good cylinders were all around 300psi(20 bar) and on cylinder 2 it was 230psi(16bar). This doesn’t seem incredibly low but is it enough to be considered bad? And to cause this misfiring problem? Thanks
