flywheel bearing
beetcedes
I have a c220 cdi 1999 which requires a new flywheel spigot bearing. Main dealer says bearing unavailable, buy complete flywheel. Can anyone please tell me if and where I can buy the bearing I need?
Many thanks
Beetcedes
Sorry cant tell you an exact answer but if you can get the number off the bearing most bearings shops will be able to supply one.
Or the size. Possibly easier as it may well be caged needle bearing with no inner or outer races to have any number stamped on. A plain bush used to be common for flywheel spigots, and if so in your case, a local machine shop could possibly make one for less cost than the price of a new flywheel.
If a bearing, once sized, as above post any bearing factors should be able to help.
If caged needles, and bearing factors can't help, have a look at small end bearings in 2-strokes - caged needle bearings are universal there. I can possibly help you match one to the size of yours.
